-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   92 Blazer cranks no crank then cranks (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/92-blazer-cranks-no-crank-then-cranks-84885/)
kwbond 03-14-2014 02:21 PM
My Blazer seems to have a mind of its own. This morning cranked right up. Lunch time turned over really slow like a dead battery. Battery is fine. After lunch turned key nothing turned key again starter clicked, turned and held for 3 seconds cranked right up. Does this sound like an ignition switch?
Any one have the same problem?
Thanks
kwbond 03-17-2014 08:17 PM
Update
Now the truck is dead tried to start it this afternoon no click everything went dead inside truck had batt checked out its good it's only a year old. I will change out the ign switch tomorrow. This is the only thing I can think of. Due to shuts all power off.
mr.vls 03-17-2014 08:38 PM
Make sure that the power cable to the starter is not grounding out anywhere.
richphotos 03-18-2014 12:39 AM
Check the connections at the battery and starter, make sure they are VERY clean.
Take them off, clean them very well.
