-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   92 S10 Blazer 4.3L vin: z (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/92-s10-blazer-4-3l-vin-z-76892/)
Zach18 Jan 30, 2013 07:39 PM
I have a 1992 Chevy S10 Blazer 4x4 Vin: z 4.3L
When it is at operating temperature and I stop at a red light or stop sign the idle dies down real low and and almost dies on me. It like dies and then comes back and makes the vehicle move forward a little. I have replaced the map sensor, throttle position sensor, Idle air control valve, egr valve, egr vacuum seloniod, fuel filter, and fixed the loose vacuum line connections. and still no luck. spark plugs, wires, and cap were changed about 3.5 years ago. i run 91 octane in it
It also has some bucking to it when i let off the gas. it doesnt do it all the time
Hanen42 Feb 21, 2013 09:35 AM
How long ago did you replace your EGR valve? These are notorious for getting dirty and causing problems like you describe. Sounds like it may be time for a fresh tune up as well.
chris015 Feb 21, 2013 09:52 AM
remove the throttle body and clean the passage ways,including the iac tunnel with a toothbrush. good ol brake cleaner works for this.
1sttimejimmyowner Feb 21, 2013 11:45 AM
I agree with cleaning the throttle body.Also spray some WD-40 or carb spray around the bottom of the tb where the shaft goes through and make the theres no vacume leaks there.
Zach18 Mar 2, 2013 02:44 PM
I replaced the egr valve about 3 months ago
ohsofly Mar 2, 2013 07:29 PM
All good ideas another idea, stop buying 91 octane gas, its just wasting your money, theres nothing wrong with the 87 that's called for. 91 is for high performance stuff, you don't get high performance by filling with it.
Captain Hook Mar 2, 2013 10:07 PM
Have you checked ignition timing with the EST wire disconnected?
Hely Oct 11, 2019 09:04 AM
I had a similar problem with mine after it sat for a while without being driven. my distributor itself was rusted out on the top and kept the spark from firing on number 3 and 5 cylinders. it wasn't until I pulled the entire distributor out that I could see it.... this might not be your problem, but your problems sounds an awful lot like me.
DonL Oct 11, 2019 04:57 PM
Hope he fixed it since 2013...
