-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   '93 blazer oil drain plug location (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/93-blazer-oil-drain-plug-location-20382/)
gooder 05-03-2008 05:07 PM
93 blazer S10 4x4
Stupid question but it is not as obvious as I thought- where is the oil drain plug located? Should it have a bolt that needs a wrench or an allen-key head that's a bit closer to the rear.
Thanks,
swartlkk 05-03-2008 06:59 PM
RE: '93 blazer oil drain plug location
Engine oil drain plug will be located in the lowest portion of the sheet metal oil pan and will be a hex head bolt requiring a wrench. It is possible that you have a skid sheild obstructing your veiw of the bottom of the motor.
gooder 05-04-2008 02:20 PM
Thank you Sir! it indeed was hidden by a skid shield.
swartlkk 05-04-2008 04:10 PM
No problem. That's what we're here for!
