93 s10 4.3l W code 4X4 timing issue
Old Nov 27, 2011 | 06:26 PM
muddymudskipper's Avatar
muddymudskipper is on a distinguished road
Default 93 s10 4.3l W code 4X4 timing issue
Afternoon all.
So I had to replace the engine in my blazer. Being the first Chevy motor I had pulled, did a quick clean, and put back in, I missed putting a new gasket on the distributor when i put it all back together, and had a hideous oil leak. I pulled the distributor and put in the new gasket and gooped it up. Now however, I think I either put the distributor back in slightly off, or I have no clue whats goin on. The truck will start, and idles a little high, but a timing light on it show that it's runnin about 50 degrees btdc....any help would be much appreciated thanks,
Old Nov 27, 2011 | 06:31 PM
Definitely sounds like the timing is off. The timing should be set to 0 degrees, but only after disconnecting the timing wire (brown or brown with black tracer) on the inside of the firewall, right of the transmission tunnel, behind/below the upper edge of the carpet.
Old Nov 27, 2011 | 06:39 PM
I had the connector in the passenger compartment disconnected, learned that trick already . Engine was running fine before i pulled the distributor. The distributor was the only thing I pulled out, and with the tab for the oil pump it only goes in two ways, what should be right and 180 degrees opposite. I bumped the motor around with the ignition until i had the timing mark @ 0, and tried to make sure the rotor button was pointed @ the number 4 position for the cap, but she definitely isn't in the right spot at the moment.
Old Nov 27, 2011 | 06:48 PM
It is quite easy to get a distributor in 1 tooth off and get the oil pump drive to fall into place properly. Does the #4 position on the cap corresponds with the #1 cylinder?
Old Nov 27, 2011 | 06:51 PM
according to what the manual says for the 93 4.3l, the timing is supposed to be set at tdc on the #4 cylinder. so that's why I went to that well. I'll try pulling the distributor back up and adjusting it back a tooth off the cam gear, maybe I'll get lucky and she'll drop in for me.
Old Nov 27, 2011 | 06:55 PM
What kind of manual are you using? My references (Mitchell1 & AllData) state #1...
Does the mark on the crank align with TDC for the #1 cylinder? If so, then time to the #1 cylinder, not #4.
Old Nov 27, 2011 | 07:19 PM
Sorry, not looking to pick a fight my first day. When I replaced the timing chain on the engine, the Haynes (#24070 82-93 s10 & s15 p/u 2 & 4 wd) shows to put the #4 cylinder @ tdc for the timing marks to all line up. Since that puts the mark on the balancer @ 0 on my timing marks, I figured that was the best thing to use sorting this out. Timing light attached to the #4 plug wire gives the reading instead of #1 as well.
Old Nov 27, 2011 | 07:51 PM
Not sure if the #4 cylinder comes up at the same time as the #1, but I am sure that I wouldn't trust what Haynes or Chiltons manuals say over the references I use. They (Chiltons & Haynes) are known to have false information.
Since the method you have been using evidently doesn't work, do you want to keep following it or give something new a try?
Old Nov 27, 2011 | 08:02 PM
I'm up for suggestions. That's why I'm here. Like I said, I'm getting ready to pull the distributor again, and see if I may have just jump a tooth or something on the cam gear on my way down.
Old Nov 27, 2011 | 08:08 PM
I'd see where you are first by turning the motor over to TDC #1 on compression. Then look at the distributor rotor and see how far off of the #1 position it is. Move as necessary.
