Adjust my Steering gear?
Old Jan 2, 2008 | 06:32 PM
Easy 8's Avatar
Easy 8 is an unknown quantity at this point
Default Adjust my Steering gear?
My steering on my '89 S10 Blazer 4x4 feels a bit loose. Isn't there a way to adjust it to tighten it up? Or do I have to replace the steering gear?
Old Jan 2, 2008 | 06:40 PM
chevcamls1's Avatar
chevcamls1 is an unknown quantity at this point
Default RE: Adjust my Steering gear?
ok there's a nut in the steering gear with a allen screw inside losen the nut first and then tighen the allen screw up about 3/4 of a turn or till u feel that is not that loose do not tigh it to much
Old Jan 2, 2008 | 06:58 PM
Chevy Lover's Avatar
Yes, there is a 5/8" nut on the top of the gear and then tighten the allen screw.
First be sure that the steering is straight ahead as this is the high spot in the gear. If it's off center and you overtighten the gear, you'll be replacing it soon.
So with the front wheels straight, steering centered, you should have at least 1" of play in the steering wheel with the engine running.
caseroj
Oct 20, 2010 08:10 AM
christianbyler
Sep 12, 2009 03:11 PM
er.rigney
Jun 3, 2009 09:16 PM
e602
Aug 21, 2006 08:05 PM
96Ls4Dr
Feb 10, 2006 12:20 AM
