Auto Gear Selector in Wrong Position
So, the title says it all, the selector arrow is pointing slightly off from the gear that the transmission is actually in. So when in park, the arrow is all the way to the left, and in OD, the arrow is in the center between OD and N. How do I fix this? Is it as simple as pulling off the trim and adjusting a wire? It's really annoying when I go offroading and I just can't figure out which gear I'm in when I'm selecting between OD, D, 2, and 1. I have to rely on the notches that I can feel in the lever.
Thanks for the replies,
BBK
BBK
My selector is adjustable from under the car, not in the trim. If you look under the driver's side you should see a lever that is attached to the selector arm linkage. You can loosen the nut, push the lever until it goes into park, and then tighten the nut.
Thanks for the replies! Problem SOLVED!
c0a8l0v6i8n9 had it right. There was a little gray string attached to a metal clip that moved with the lever. This was simply out of adjustment. A few minutes behind the trim of the steering column and the job was finished.
I think what workshop4ever was talking about was the connection between the lever and the transmission, which was not my problem. Useful information to know, and thanks for suggesting it, but it was not the fix here.
How do you go about makin it go into park?
This is an old thread, but to make it go into park you just manually move the gear lever on the transmission.
but I am not sure what workshop4ever is talking about, if your gear indicator on the dash is not showing what gear you are in. You remove the trim that is below the steering column. once that is done, there is a little metal clip that hooks onto the column, so when you turn the column it moves that little indicator on the dash to show you what gear you are in, in relation to what gear the transmission is in.
First, put the parking brake on, put the truck in neutral, then remove the under dash trim on that side, find that clip, adjust it until it shows that it is in neutral. put everything back together and you are good to go.
if you are having another problem besides the one that is described in this thread, please start another thread.
caseknife64
May 24, 2015 07:33 PM
yardbird
May 14, 2013 01:21 AM
SoapyTheCat
Nov 30, 2010 07:21 AM
Shaggy
Jul 30, 2010 09:03 AM
er.rigney
Jun 3, 2009 09:16 PM
