| mr.vls |
08-10-2009 06:07 PM |
Back Glass Rattle Eliminated
2 Attachment(s)
I have owned my S15 Jimmy since new. The back glass has always rattled. I adjusted the latch, used electrical tape. Adjusted the tail gate and any thing else I could think of. Well I had an idea in my head that if the catch in the tail gait was not so narrow that it could secure the glass much better. I measured the Dia. of the latch on the back glass and the opening in catch when the catch was in the closed position. The Dia. of the latch was 1/4". The Dia. of the catch opening is 5/16 ". However the end of the catch is narrower. I went to Home Depot and bought a 1/8ipsX 2" brass pipe nipple. The inside Dia. of the pipe nipple is exactly 1/4" and the outside Dia. was over 5/16". First I ran a 1/4" drill bit to ensure it was nice fit. Then I used my bench grinder to mill the outside Dia. untill the pipe nipple would fit inside the catch on the tail gate. Once that was done I used a dremel tool to cut the pipe nipple almost in half to allow the I/4" drill bit to enter and exit the remaining half without binding. I then cut the length of the cut away pipe nipple to match the width of the tail gate latch. I then used epoxy to secure the cut away pipe nipple in the catch of the tail gate. This eliminated 98% of the rattle. The last piece was to put a piece of tubing over the alignment pin (On the Glass). Attached are the pics. of the tubing on the alignment pin on the glass and the fitting on the catch. There is a little bit of grease on the latch that shows up in the pics. but the fix works great.
