batt cable
i notice that the neg cable at the terminal was melted. does that mean i have a short? if it doea how do i go along to find and fix it?
SORRY MAN IM NEW TO THIS FORUM.STILL A LIL CONFUSED ON HOW TO FIGURE THIS SIGHT OUT. THANKS FOR THE INFO. I HAVE A DIM LIGHT WHEN I TEST THE FUEL PUMP POWER SUPPLY. WHAT DOES THAT MEAN? |
RE: batt cable
it could have had a bad conection between the battery and the cabel causing it to get hot and melt
RE: batt cable
WHAT SHOULD I DO? CHANGIT IT? AND WHERE SHOULD I BEGIN ?
RE: batt cable
where should i begin. what to do. im clueless
RE: batt cable
I would just go to a parts store (Advance Auto Parts, AutoZone, NAPA, etc.) and ask them if they have a negative battery cable for your blazer, they might have something that is a universal fit too. I would just ask them since noone else is jumping on this problem. Also if you have something else to add please use the edit function instead of double posting on your thread unless someone else has responded. Thanks, hope this info helps.
