Bleeding brakes 93 s-10 blazer
Can someone help me out with this question? I have a 1993 s-10 blazer and I broke a from brake line while driving (so I pumped the brakes with the line broke). I replaced the line and blead the brakes, but I can't seem to get the abs brake light off. Could someone tell me the procedure for this?
Thank you...
Thank you...
With an attitude like that, I'm not sure why I am responding... AuburnBlazer is mostly correct. Your truck requires a special tools to properly bleed the entire brake system (if that is the only thing causing the light).
You might want to get the RWAL/4WAL controller scanned to see what the code is first as it may be something unrelated.
Next time, why not ask "why?" rather than spitting in the face of someone that has taken their time to respond to your post.
Is there something on my truck that i need to do other than the normal bleeding process? 1994 full size blazer w/ABS.....Thank you in advance!!!
1) Turn Ignition to "ON"
2) Insert paper clip at A & H for "Two Seconds"
3) Remove for "One Second"
4) Repeat #2
5) Clearing is successful when the "Anti lock" AND "Brake" lamps light up THEN turn "Off".
Drive the car and see if it lights up again. If so, check the code. That would point you toward the problem.
lunghd
13
Mar 17, 2013 09:49 AM
toms2000blazer
Jul 26, 2012 04:46 PM
Chic_Bowdrie
17
Apr 3, 2012 10:16 PM
flamez2647
Jul 28, 2009 09:40 PM
chvygirl84
Nov 20, 2008 08:45 AM
