-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   Bought a Jimmy yesterday with a few issues... (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/bought-jimmy-yesterday-few-issues-39324/)
Eff10 Jan 15, 2010 07:43 PM
I just bought a 94 Jimmy yesterday. :) My boyfriend has a 94 blazer and I loved it so much that I wanted one for myself. It's currently in primer with 157k on it. I plan on having it painted. There are a bunch of small things wrong with it that I plan on fixing like the passenger window motor, but most of the problems are very small and not a big deal.
The one thing that is driving me nuts though is the 4 wheel drive. I've never seen a problem quite like this so I would really appreciate some help with this issue. The 4 hi won't engage. It just blinks. I know that this is a common thing but the weird part is that the 4 lo does engage most of the time. The problem with this though is that sometimes it engages properly and the light stays on, but sometimes when pressing the 4 lo button both the 4 lo and 4 hi lights are on simultaneously. Also, after finding this out today, I switched it back into 2 wheel and when I went to drive it, it was clearly still in 4lo even though the light wasn't on. I engaged it again and disengaged and that fixed the problem.
What would cause the 4 hi to not want to engage even though the 4 lo will? Also, what does it mean if both of these lights are on at the same time? My boyfriends blazer has the exact same setup and I know his does not do this.
Thanks for your help!
Here's some pictures, and yes, I promise it's a Jimmy. Whoever owned it before must have wanted a blazer pretty bad because they changed the grill and the rims. It was originally blue, so I'm thinking about painting it a dark blue.
http://i17.photobucket.com/albums/b8...Picture007.jpg
http://i17.photobucket.com/albums/b8...Picture008.jpg
http://i17.photobucket.com/albums/b8...Picture009.jpg
vortecjimmy Jan 16, 2010 10:16 AM
I had this same problem with my 94 jimmy and it was the solenoid on the transfer case, think it cost almost 300 bucks.It makes a quik mechanical engagueing sound when i lock in and out ive noticed now with it working right.
I am not a mechanic i'll let you know, but this is the same problem i had, gl and cg's on your new jimmy.
Eff10 Jan 17, 2010 02:45 PM
Thanks for the good wishes. I'm really bummed out about this whole issue. Thanks for your insight. Does anyone else have any ideas or agreements with the solenoid diagnosis?
Leeann_Bravada Jan 19, 2010 08:48 PM
I'd check the easy stuff first - check all your vacuum lines and the vacuum actuator under the battery tray. That's a lot cheaper ;)
Eff10 Jan 20, 2010 09:06 AM
Will do. I'll let you guys know what I find out. Thanks.
samuknow Jan 20, 2010 11:49 AM
Is it push button 4wd? I had an issue where my 4wd was staying engaged, not engaging, and trying to switch on it's own. I pulled the push button control and cleaned the contacts under the buttons and it has been great.
Eff10 Jan 21, 2010 09:10 PM
I'll definitely try that. How did you get the button off and what did you clean them with?
NVANZEE Jan 21, 2010 09:14 PM
Sounds like the encoder motor is going bad.
Eff10 Jan 21, 2010 09:26 PM
Sorry for being a noob but could you explain what an encoder motor is and how to go about fixing it/getting a new one?
Spectreblazer Jan 21, 2010 09:35 PM
a girl that knows something about trucks.:icon_special:
i'm impressed.
