Can I switch from 4wd to AWD ???
Not sure if this is the appropriate section for this question but it will get moved if it isn't ..... anyways I am wondering how hard would it be to convert my 4wd 89 S10 Blazer to AWD I searched around and people were saying that some parts from an AWD Astro would work is this true and if so how much time and money am I looking at spending. Only reason I want to know is because I want to make a Typhoon clone it is going to take a while I know but it will be worth it in the long run.
I believe you can use the AWD transfer case from an Astro, OR you could get all of the parts you need from a first gen Olds Bravada since those were AWD from the factory.
The parts I recall hearing you'd need from when I considered this are: transfer case prop shaft front diff (not sure about that, but I think you do because it's always locked?) CV shafts and obviously some way to cover the hole in your floor when you remove the 4X4 shifter. Not at all an exact list, but those are the parts I can recall. Depending on how many of those parts you can source from a junkyard and/or finding a Bravada with those parts you can pilfer... I'd guess you could do it between 500-1000 bucks or so. Keep in mind though, those are stock parts, so you'd want to make sure you rebuild them to handle the HP and Torque load you're looking at too, which will raise your price up. |
Yes, it's true. You would need the transfer case, driveshafts, & adapter at the least. To do it right, you would also need the front axle (or at least the passenger side drive shaft & extension housing). The front axle in any of the AWD trucks lacks the disconnect found in the selectable 4wd trucks.
Ha. Sniped! |
what would be the advantage/ disadvantage of this?
Disadvantage: no more smokey rear-only burnouts, probably worse gas mileage.
Advantage: better traction all the time |
only reason I am looking into this is because I want to attempt to make a Typhoon clone I know it will be hard and take me a LONG LONG time but hell I am up for a challenge lol
I looked to doing the same thing w/ my bravada (w/ comp controlled awd) which is all the same as a typhoon.. & heres the big part.. Keep in mind that I've only read about it.. but "supposably" the obvious differance are the transfer ("The Borg Warner units used in the pre-98 AWD applications (Bravada, select Blazers, Typhoon, Syclone, & the vans) was a dedicated torque split. The newer ones are adaptive. I can't remember if they used the same marketing name for the earlier Bravadas... " -SWARTLLK) & front end drivetrain, but I've read the motors have a diff cam & I believe something was different w/ the heads or pistons.. or both. I'll hunt around & see if I can't find the article that I read on them.
Smarttrack was the designation for AWD on the first gen Bravadas.
I may be in over my head lol :(
One good way to learn...
Well, two I suppose. One is to take classes and pay a buttload of cash. The other is to do your research, buy parts, and do it yourself. |
| All times are GMT -5. The time now is 08:24 AM. |
