Can't drop fuel tank
Hi everyone,
I'm spraying gas from the top of my gas tank. I tried to drop the tank to see what the problem is and fix it but the bolts holding it up won't budge. So I'm considering removing some carpet in the back and cutting a 12"x12" hole in the floor so I can access the gas tank from above. Does anyone have any suggestions on how to go about doing this without destroying my interior?
I used the 'search' function and found several posts for 'remove fuel tank'. Here's a link to one of the threads.
https://blazerforum.com/m_43452/tm.htm
You are really much better off either cutting the straps that hold the tank up or breaking off the bolts on the straps themselves with some good old fashioned muscle. Reason I state to break off the bolts is because you don't want to go throwing sparks if gas is present... Cutting a hole in the floor presents the same difficulties with fuel vapors present... Destroying your interior would be a mute point if the truck caught on fire...
Anyway, hope this helps!!
ouch you coulda saved some money there remember one thing patience is key to fixing your rig if you get mad or frustrated take a break and come back to it especially if there is rust present or something preventing an easy fix have patience, withthem you will save money and gain knowledge!!
