code 44. Lean. oh yay.
Old Apr 21, 2013 | 07:27 PM
chris015's Avatar
Default code 44. Lean. oh yay.
popped up today on the way to the store. Truck runs great. doesnt miss a beat,no loss of power. just the annoying lights on now.
I tested the temp sensor while hot. tested at 276 ohms. Im running a 180 stat.
Only thing i done was advance the timing by ear a few degrees. but that was like 2 weeks ago. if it would of affected it,it should of by now.
Old Apr 21, 2013 | 07:52 PM
xgiovannix12's Avatar
Hope this helps you Chris...
Attached Thumbnails code 44. Lean. oh yay.-dsc00549_zps177900eb.jpg   code 44. Lean. oh yay.-dsc00550_zps82553a6b.jpg
Old Apr 21, 2013 | 08:41 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
whats up with everyone and advancing timing? Keep it at 0 it works best there if the truck is stock. If GM could get more hp and mpg out of it by advancing it a few degrees then they would tell you to from the get go. Too far advanced can cause a lean condition. As well as everything xgiovannix12 has posted, "vacuum leaks, exhasut leak before sensor, low fuel pressure, bad sensor, and so on".
Old Apr 21, 2013 | 08:45 PM
chris015's Avatar
its not stock though. full exhaust,intake,ignition,tbi mods,93 octane,etc. it helps the "tad bit of lazyness" you feel off idle. i ran 6.5 advanced on my old blazer. it was a small difference compared to 0. never had this problem.
Old Apr 21, 2013 | 09:06 PM
Ah, your TBI. With all the mods listed you really need a tune to allow for slightly more fuel. That right there could casue a lean condition. But the hard changes that warrent a timing change would be upping compresion ratio, forced induction or a different cam. Or a tune that want a different baseline. 6.5 is just border line of being too far off. At 7 there is a noticeable power loss in the low end on TBI and CPI engines. How far advanced is your truck now?
Old Apr 21, 2013 | 09:17 PM
chris015's Avatar
On my old blazer,i cheated and put a quarter on the regulator spring and bumped the fuel enough to compensate for the lean condition. I kept a eye on my plugs until i got it right. You are right,i do need a tune and will be using blackbear or tbichips. Im not sure where im at right now. Tomorrow im going by a shop i have work i dont wanna do done and borrow his timing light. i did move it much at all. If any Since i broke my timing light. I do need to rebuild the tbi on this thing too. Im sure it'll help.
Old Apr 21, 2013 | 09:28 PM
Rebuilding the TBI could help, thats a major source of a vacuum leak right there! Man get a mild cam and better flowing intake and that thing would come to life with a good tune!!! Dam wimpy stock cam in the TBI engines is one of the biggest flaws to it.
Old Apr 21, 2013 | 09:35 PM
chris015's Avatar
yea they are. I replaced the tbi gasket that mounts between it and the plenum. Engine runs sooooo smooth. no way it has a vac leak. I orta put a quarter in the regulator on this one and see what happens. Nothing to loose but 30 min of my time.
Old Apr 21, 2013 | 09:43 PM
Wouldnt hurt.
Old Apr 22, 2013 | 06:46 PM
chris015's Avatar
checked timing today. Whoever put the engine in didnt set it correctly.it was 15 degrees advanced. crazy the truck even ran without pinging. I guess im glad the knock sensor probably retarded it. anyways,that didnt fix the light. Im going to toss a quarter in it tomorrow and see what happens. later this week il get a fuel filter too.
