-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   CPI unit (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/cpi-unit-40963/)
00bluegtp 02-17-2010 02:52 PM
CPI unit
How does this thing conrol fuel to 6 different cylinders with 1 injector? Does it turn to each nylon line to allow fuel into them seperatly? How does this thing work?
swartlkk 02-17-2010 03:05 PM
I have posted this before...
The CPI fuel system is a batch fired system meaning that it supplies fuel to all cylinders at once. There is one central electronic fuel injector that feeds 6 individual pressure actuated poppet nozzles. These poppet nozzles will only open when the pressure exceeds a preset limit (somewhere around 52psi). When the electronic injector opens, fuel pressure is fed to the poppet nozzles causing them to open and squirt fuel into the intake runners. When the electronic injector closes, the pressure inside the nylon lines drops until the poppet nozzles close.
00bluegtp 02-17-2010 03:34 PM
Thank you for the quick answer. Wow I cant beleive that it even works. So the fuel just sits in that runner till each intake valve opens? That sounds kind of wacky.
swartlkk 02-17-2010 03:42 PM
It's not a whole lot different than a carb motor. Even at 600RPM, each intake valve is opening up 5 times per second. There isn't much time for the fuel to just sit there.
