Crank, Cranks, and ranks won't start until?
I tried all starting fluid I had and it tried to start. I put just a bit of gasoline in each side of tbi and it fired right up. I am right that it is the fuel pump or completely clogggged filter? I took supply line loose from tbi turned key on and could see no gas being pumped nor could I hear the fuel pump back at the tank. I am at a loss, PLEASE ADVISE
sounds like you have a bad fuel pump
Yup, most likely a bad fuel pump, but if you have a voltmeter check the voltages on the wires before going thru the hassle of dropping the tank.
if u dont hear the 'buzz' of the fuel pump turning on with the key in the on position then yes with your symptoms it is most likely the fuel pump that is bad
Problem fixed
I Followed each and every suggestion to the letter, doing so It helped my moronic complex. Thanx to the guys for chewin my butt off, it worked. I repfalce all fuelo pump goodies and it runs like a champ. New fuel filter, complete internal cleening of the fuel teank. I wanna sai thanx, i apologize fro jumping to conclusions and getting my azz chewed up in oer to line me out. As always thanx a million.
| All times are GMT -5. The time now is 11:11 AM. |
