-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   CV boot inner front right (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/cv-boot-inner-front-right-101441/)
Koteli 04-04-2020 07:31 AM
Hi all
Someone tried to replace the inner rubber boot without removing suspension ?
thanks
Koteli 04-04-2020 08:36 AM
https://cimg9.ibsrv.net/gimg/blazerf...052389b218.jpg
christine_208 04-04-2020 04:13 PM
Perhaps. I think I've heard of people being able to get the axle shaft out without removing the ball joints from the steering knuckle but I've never been able to do it. But once you've gotten that far into it, you've already taken off the brakes and maybe the hub. Doing the rest is not so bad.
Koteli 04-04-2020 05:42 PM
CV joint boots inner
thanks Christine
I took a look and maybe possible on left side removing the lower shock absober screw only , I I believe better than removing knuckle. I will try before remove suspension . the car was abandoned on a farm during 15 years and there are mud , soil , include rats ****. I am greasing all before removing ...I check the original boot size and one from Volkswagen T4 is equivalent size .
thanks from Spain
thanks from Spain .
Koteli 04-06-2020 12:34 PM
Hi all
It is possible only unscrewing the shock absorber from lower bolt and releasing the sterring tie rod from main steering bar. I dismounted the inner boot for fix it , tit is damage due the small bracket is broken , the boot was dislocated and rubbing the shock absorber.
all of boots are original from 88 and plastic made
Koteli 04-08-2020 04:58 PM
88 S10 4WD CV front boot right vs left
Hi all
I had problem with boot , taken measurement and comparing left vs right , the right axle is shortest than left however the part number is the same for both so the right boot is more compresed than left boot . the small bracket was broken and the boot impacted with the shock absorber. the boot was not original , the same model (made in Canada) but newest than the car, boot is from 93.
the question is how to find replacement. in Rockauto there are two model , thermoplastic or rubber. which is better ?
I think this is a design problem from factory. however i dont understand why because everything looks like normal.
I am trying to find equivalent boot from european manufacturer and it is very hard to find...
thanks from Spain
error_401 04-10-2020 07:36 AM
Merged to keep the threads together as they are related.
The front CV axle boots are not easy to replace. It should work with any boot that fits both diameters that of the axle shaft and the CV. From my experience replacement would require to take the whole front hub apart as the new boot will have to slide over from the outside.
Stro53 08-04-2020 09:52 AM
Wouldnt
I just replaced the cv axle shaft and while at that seen the upper/lower ball joints were shot and the upper control arms..But you are.gonna.wanna remove the knuckle for.better results..
