-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   Digital Gauge Cluster Failing (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/digital-gauge-cluster-failing-87500/)
1992Jimmy 10-13-2014 11:06 AM
Hey everyone, I'm new to this forum but i'm certain this place will prove to be a very useful tool when searching for answers.
Anyway, I bought a 1992 Jimmy SLE 4x4 4.3L Engine code Z.
My digital gauge cluster i believe is starting to fail (because its blicking), ive read that it may need a new capacitor? idk
What i would like is to just get a salvage yard backup cluster in case the current one decides to die.
My question: Has anyone done a cluster swap before? What years and models will work for my vehicle? Any info will help.
Thanks
Blazin_Jason 10-14-2014 06:38 PM
You can attempt to fix it yourself, depending on the issue. You can also buy repair kits on ebay, or send it in for a repair. Are you looking for a digital cluster to replace with or go to analog?
1992Jimmy 10-15-2014 08:22 AM
If there was a digital or analog cluster that would fit my jimmy, i'd use it.
Blazin_Jason 10-17-2014 05:32 PM
A digital R&R will be easier, but the mileage will change with the new cluster (not a huge deal). An analog swap can be done but would take some work.
Link
Link
1992Jimmy 10-21-2014 06:54 PM
thanks for the links! this will come in handy if i can find an analog cluster at the pull-it yard.
Fireitup 10-22-2014 07:42 AM
I ordered the kit off ebay. Just replaced the components on the board yesterday and it works great now!
This is the kit i ordered, it comes with all needed to do the repair other than the soldering iron.
89 94 Chevy S10 s 10 Blazer Digital Cluster Repair Kit | eBay
Edit:
On a side note anyone happen to know what i hook the cable to for the gear selector part of the cluster?
richphotos 10-25-2014 12:39 PM
That is a good kit, that is the one that I used. I live in MN so I picked it up directly, Good guy.
as for the cable, under the steering column is where it hooks to. its hard to describe
