Drivers side power mirror. no side to side, is there a relay? or just the switch
I have a parts jimmy and a nice 93 GMC S15 jimmy
My problem is my passenger side power mirror works completely up/down, left/right. but then on the drivers side the power mirror will only go up/down. The parts jimmy mirrors work completely. So I first changed out the mirror, and when that didnt fix anything I changed out the switch. Still not fixed.... so now I can only assume there is a relay OR if there are no relays for the mirrors, then I must have a bad wire somewhere... Anyone have any ideas? |
Go to your local library. Find out if they have access to the Mitchell on-line repair manuals. If they do, get on the Mitchell website and look up the testing procedure for the power mirror circuit. It's very thorough. I used that testing procedure for the mirrors on my '94 Blazer.
killer thank you so much! I have already completely ruled out the mirror and the switch.
but im just not sure what that leaves... lol! I will check out the library in the next few days. |
There are no relays in this system. Locate the mirror connector (in the door) and check for power to the switch. Yellow & Green wire is the up & down. Blue & White are the right & left, you can trace from there.
As said, it is all wiring. Sounds like there is a break in the wiring for the driver side mirror.
thats what i was afraid of, doh! I will trace it down in the next couple days, thanks guys!
| All times are GMT -5. The time now is 04:41 AM. |
