e-brake idiot light always on
Old Jan 4, 2006 | 06:33 PM
Philly Assassin's Avatar
Philly Assassin is an unknown quantity at this point
Default e-brake idiot light always on
Long story short, in late November I crashed my truck. 180'ed hit a curb and broke the tire clean off the axle. I had to change the entire rear. Well i belive i have everything fixed its just that my ebrake light is always on. Could I have broken the sensor that triggers the light? How can I fix this problem? Its a 1990 S10 Blazer 4x4.
Old Jan 4, 2006 | 06:39 PM
Default RE: e-brake idiot light always on
Not sure on the previous gen Blazer, but I believe there is an electronic sensor on the ebrake bracket under the dash. Have a look up there, it is possible that the sensor just went bad and needs replacing. I'm sure that it doesn't have an adjustment. It is possible that the spring that holds the pedal up has either broken or gotten weak. Will the light go out if you pull up on the ebrake pedal? Give that a try and if it does go out, then you may need to either replace the spring or just add another one into the bracket.
Rusty Piece of Love
Jan 23, 2014 10:40 AM
rodeofan5656
Jan 19, 2013 10:44 PM
bullwinkle
Oct 12, 2009 06:29 AM
Zasder
Apr 2, 2008 08:16 PM
TheGuardian08
16
Oct 3, 2007 06:23 PM
