-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   e-brake idiot light always on (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/e-brake-idiot-light-always-1964/)
Philly Assassin Jan 4, 2006 06:33 PM
Long story short, in late November I crashed my truck. 180'ed hit a curb and broke the tire clean off the axle. I had to change the entire rear. Well i belive i have everything fixed its just that my ebrake light is always on. Could I have broken the sensor that triggers the light? How can I fix this problem? Its a 1990 S10 Blazer 4x4.
swartlkk Jan 4, 2006 06:39 PM
RE: e-brake idiot light always on
Not sure on the previous gen Blazer, but I believe there is an electronic sensor on the ebrake bracket under the dash. Have a look up there, it is possible that the sensor just went bad and needs replacing. I'm sure that it doesn't have an adjustment. It is possible that the spring that holds the pedal up has either broken or gotten weak. Will the light go out if you pull up on the ebrake pedal? Give that a try and if it does go out, then you may need to either replace the spring or just add another one into the bracket.
