-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   EGR valve not working right (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/egr-valve-not-working-right-63503/)
bam_9_9_9 09-26-2011 11:39 PM
Got a 94 s10 blazer vin W. got a code 32. so i just replaced the egr valve with a known working one and a new gasket. 10 min of driving engine light comes on. code 32. shut the engine off and back on and the light is off. drive another 10-15 min or going down the highway it will come back on. so whats going on. when i took the old egr out it had some oil on the pintle and some in the holes. i dont know why. anyway how do i go about testing the wires going to the egr. i have a voltmeter/ohm meter. the engine runs great all the time no problem. i think that the egr is not opening up when commanded on. the old and used egr pintle moves in and out freely and wasnt much if any carbon in or on the egr when i took it out. thanks
bam_9_9_9 10-06-2012 10:03 PM
bump?
NCSurvival 10-07-2012 08:48 AM
Sometimes, when ya take those off, it's best to spray cleaner down in the port, and a tooth brush down into it to scrub. Then fire up the truck and rev it to blow out any carbon chunks that may be lodged. It's loud, but works.
ohsofly 10-07-2012 11:31 AM
Make sure to use cleaner and a pipe cleaner in yhe passages thru the intake too. Yes you cam test em eith your meter too. PM "swartkk" for the specs i dont remember what tjey are
