-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   Engine "Dieseling" - continutes to run after being cut off (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/engine-%22dieseling%22-continutes-run-after-being-cut-off-12201/)
BradensCreed 08-02-2007 09:36 PM
what are the most common reasons my 84 2.8 v6 carb motor would do this? let it warm up and idle for a while, cut it off and it chugs and sputters till it dies, usually about 5 seconds. hitting the gas makes it almost rev then die. has been sitting for six months. got it from a guy for a good price... if i can diagnose this.
joseph296 08-14-2007 08:58 PM
RE: Engine "Dieseling" - continutes to run after being cut off
i jsut solved this problem in my 94 v6 it was flooding due to a bad fuel preasure regulator
drperry 08-15-2007 06:46 PM
Totally unrelated to his engine... There is no pressure regulator...
The carb could need rebuilding, or if your lucky just some tuning.
swartlkk 08-15-2007 07:44 PM
I made a pretty thorough post on engine run-on a while back... Here ya go --> CLICK HERE
BradensCreed 08-24-2007 11:24 PM
not bad. got a can of sea foam and checking the timing as soon as i can. def needs a good tune up so thats going to happen regardless. quick question... what are the benifits of using sea foam in your oil as well as in the gas?
swartlkk 08-25-2007 03:22 PM
Seafoam in the oil is to clean out any deposits in your engine oil system. It should only be run for 250 miles MAX. In the gas it acts as a fuel injector cleaner, but there are better alternatives for fuel injector cleaners.
