Engine died while driving won't start No check engine light with key on
Old Jul 31, 2012 | 12:33 AM
doccheese's Avatar
doccheese is on a distinguished road
Default Engine died while driving won't start No check engine light with key on
1988 S10 blazer 2.8 4x4 manual trans
Help!
I was driving tonight everything dandy, good oil pressure and temp good. Then engine just quit, like someone had just unplugged it. No stammering or stuttering just flat quit. Coasted to a pull out on the road and tried to restart it, turned over fine but nothing. Turned key to the run position and the service engine light was not on as it should be. Would a failed ignition module cause these issues?
Thanks in advance for any help out here.
Old Jul 31, 2012 | 10:56 AM
doccheese's Avatar
I am going to have the ignition module checked this morning and will post results later.
Old Jul 31, 2012 | 01:07 PM
doccheese's Avatar
Default fixed
Turned out to be scale build up on ecu fuse. Was not burned just scaled with corrosion just enough to kill the circuit. Go figure.
Old Dec 12, 2014 | 03:43 PM
Nancy Pennington's Avatar
Nancy Pennington is on a distinguished road
Im having same issue only sometimes it will start back but then just like i turned the engine off fuel pressure good changed fuel filter dist cap&rotor still cuts off&wont start back
sunchiropractictables
Mar 2, 2024 06:29 PM
Jeremy_in_Texas
Jan 24, 2015 06:58 PM
zstudna
Oct 15, 2012 07:19 PM
mechelle207@yahoo.com
Aug 18, 2011 08:29 AM
sagoo33
Jul 29, 2010 06:53 PM
