-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   Engine Tech Help Needed (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/engine-tech-help-needed-178/)
jp5162 11-08-2004 08:14 PM
94 Blazer 4.3 vortec
120,000 - well maintained
Fuel injection assembly has been replaced
Starts hard at times and has a rough idle - almost like the motor is skipping
New plugs and rotor, spark plug wires only a couple years old
Fuel filter and fuel pump has recently been replaced
?? possible oxygen or map sensor - not sure - any suggestions
Lost - please help!!!
MeandMyChevy 11-25-2004 05:37 AM
RE: Engine Tech Help Needed
Try running some "Sea Foam" motor cleaner through it, it come sin a white and red can, about 5 bucks. I just through a can of it in my tank to try and clean my injectors out. I havent read one bad thing or heard one bad thing about and I researche dit for like 2 hours. i go tmine at Auto Zone. Try it out and if you follow the directions then it will clean every bit of anything thats bad out of your engine. Heres a detailed intruction link. http://members.nuvox.net/~on.roz/cars/z28/seafoam.html
jtroske 11-27-2004 09:51 AM
IF YOU'RE RUNNING A VORTEC TRY CLEANING THE IAC OUT WITH CARB AND CHOKE CLEANER.IT MAY BE STICKING OPEN GIVING THE ENGINE TOO MUCH AIR AT IDLE
