-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   Factory Plug Gap on Beefed up 4.3? (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/factory-plug-gap-beefed-up-4-3-a-74058/)
NCSurvival 09-26-2012 12:28 PM
Ok, so my question is, when you change the engine displacement, does the plug gap change at all? I have a 4.3 TBI bored over .060, running flattop 350 pistons, mild Comp cam, MSD ignition system and distributor. ECM is chipped with Edelbrock chip, and running Venom injectors. If I did my math correctly, the engine is now nearly a 4.5L.
Blazin_Jason 09-26-2012 07:21 PM
Most people who upgrade the ignition coil and components, tend to like a slightly larger gap. 0.040-.045 if I remember right.
NCSurvival 09-27-2012 06:01 PM
ThanksI will try that on the next plug change.
chris015 09-27-2012 06:53 PM
My plugs are gapped around 40 from normal wear. Noticed a bit of a mid end improvement. compared to factory gap, but Ive got alot of mods done. They do look like they are running a bit hot though. I need to replace em anyways.
NCSurvival 09-28-2012 09:12 AM
My engine was designed to throw all the torque in the mid and low ranges. Anyhow, shouldn't hurt to try 40 to start, see what kind of changes I get, and go from there.
chris015 09-28-2012 11:17 AM
If you wanna play with that #3 plug more then once lol gap em around 45. Drive it and then gap it at 40 and try again.
ohsofly 09-28-2012 04:58 PM
Number 3 is a breeze if you have a meter long extention. I do mine from the wheelwell amd its a snap.
chris015 09-28-2012 07:05 PM
ive actually got a tool for #3. its a t bone looking extension with a knuckle and a 5/8th socket attached to it. works great
