front end squeek
been doin alot of mud boggin and barried it a couple of times, washed it and now the front end squeeks any ideas?
Were you going through lots of water? If so, you can get water into the u-joints causing a squeak. It may be as simple as just greasing the front end.
I bogged mine down in some mud, and caused a wicked sway bar squeak. Try greasing it all first like swartlkk said, if that doenst work, take apart the sway bar and lube it up, then reassemble.
| All times are GMT -5. The time now is 02:16 PM. |
