-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   GMC Jimmy s15 help asap (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/gmc-jimmy-s15-help-asap-70020/)
richphotos Apr 17, 2012 02:12 PM
Originally Posted by pettyfog (Post 514502)
The next option is your oil press sender. Pretty sure that part of it's right. Just right of distributor
Pull the connector. It has three pins. Disconnected, one will be 12v to gnd either all the time or all the time with key on. One will be 5volts with key on: that goes to dash press gauge.
One will read no volts. It may be gray. Taht one is the one that holds the fuel pump on, when running it is the other side of switch to twelve volts. On it you should read less than 15 ohms to gnd.
If you have someone turn key on, it should read 12 v for two seconds.
ALSO in many the FP relay is behind dash
Key on should hear a click, two secs later another click as it turns off.
The fuel pump relay on the jimmy is located on the cowl/firewall drivers side, right next to the wiper relay, I tested that first last night by swapping the 2 of them (since its the same part) thinking that it could be the relay, and the truck still did not work.
pettyfog Apr 17, 2012 02:22 PM
Okay.. forgot! I guess it's 95-97 that is behind dash. {?}
Anyway.. I AM pretty sure the Press sw test applies because I looked up the sender on rockauto.
{Also on every descr of the 12 pin aldl I can find 'G' is the FP test, but that doesnt matter, here.}
richphotos Apr 17, 2012 02:41 PM
Yeah, the pump is dead as a door nail. I appreciate you walking me through this.
I will have the pump/sending unit by thursday or friday (the lines looks real rusty at the sending unit, so i decided to kill 2 birds with one stone and get it all. 220 shipped instead of 310 at napa or orielly
pettyfog Apr 17, 2012 02:43 PM
Oh damn! NOT AIRTEX!!!! Delphi or AC DELCO only!
richphotos Apr 17, 2012 02:57 PM
Yup, got me a Delphi :)
Max_Power Apr 17, 2012 03:01 PM
go give the fuel tank a few kicks or thwocks with a rubber hammer and try. Sometime if you have just gotten to that point the fuel pump will start a few more times. Just a easy diagnostic trick...but doesn't eliminate anything unless it works. You can also spray a bit of starting fluid into the intake and see if it comes alive for a few seconds.
richphotos Apr 17, 2012 07:26 PM
Well, one thing about being a body man, I am not dropping the tank to do the fuel pump/sending unit, Just going to pull up the carpet, cut a hole in the floor.
richphotos Apr 18, 2012 08:22 PM
Any tips before tackling this job?
workshop4ever Apr 19, 2012 02:00 PM
start spraying the fuel line fittings now with PB blaster or equivalent. I know you have a new sender, but it's always easier if the parts come apart rather then breaking them....
richphotos Apr 19, 2012 02:07 PM
Sprayed the fuel line fittings, this is what it looks like, Looks like the previous owner took out the sending unit, and broke one of the fittings and did this, any tips on what to do now with the new sending unit coming soon
plus a couple pics of the hole I cut
Here is the hole
http://i874.photobucket.com/albums/a...1/DSC_3345.jpg
and here is the hack job previous owner did, suggestions on this please, never had to deal with anything like this before
http://i874.photobucket.com/albums/a...1/DSC_3346.jpg
