-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   has any 1 used this stuff before ? (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/has-any-1-used-stuff-before-65209/)
xgiovannix12 11-19-2011 08:30 PM
well i decided to fix my rear window struts and i found that the defroster tab wire broke
would this product do the job ? any 1 used it before ?
Permatex 21351 - Rear Window Defogger Tab Adhesive | O'Reilly Auto Parts
Captain Hook 11-19-2011 08:44 PM
Yup, good stuff, used it many times. It does what it's supposed to do if you follow the directions: adhesive that conducts electricity. They also make a product that you can "paint" on if one of the lines of the defroster breaks, that's good stuff too.
xgiovannix12 11-19-2011 08:47 PM
sounds good then
Ill pick some up in the morning when i get the struts
xgiovannix12 11-20-2011 04:06 PM
alrighty i bought it but it didnt work on the wire on one side
it did work on the other side tho
the passenger side tab is still on but the wire broke off the tab
I guess i need to solder it
IM open to suggestions tho
Edit: This is how it broke
the tab is still on the glass
http://i1130.photobucket.com/albums/...2/PICT1344.jpg
Captain Hook 11-20-2011 05:06 PM
Ahhh, piece of cake. Solder it back together using rosin core solder. DON'T solder on the glass... BOOM, big mess.
xgiovannix12 11-20-2011 05:16 PM
so i need to remove the tab? i was looking at something called solder paste
i think it hardens like solder when done
Captain Hook 11-20-2011 05:33 PM
Did the spade terminal break off of the tab that solders to the glass?
xgiovannix12 11-20-2011 05:36 PM
the tabs on the glass its self the wire broke off the tab its self
Captain Hook 11-20-2011 05:37 PM
Got a picture of what's left on the glass?
xgiovannix12 11-20-2011 05:39 PM
nope i can go out side to take one but i dont know if its going to come out
