Headlights out
Hey all,
1991 S-10 Blazer So my headlights went out after we saw avengers endgame. After I got home I checked all the fuses under the steering wheel, all fine, then I played with the fog light switch a bit and they came back on. All was fine for a couple days then BAM, they went out again. I played with the fog light switch some more, but nothing happened. I tried replacing the headlight switch, and fog light switch, but that didn't help. The headlights are new and were just replaced about a month ago. When I turn the switch on the dash lights come on, and the high beam indicator comes on, but when I pull the lever the indicator stays on. Any ideas? Is it a ground issue, if so where do I find the headlights ground? |
Nevermind, I got it fixed the connection that splits off from the headlights and goes to the horn was loose.
Glad you got it figured out!
| All times are GMT -5. The time now is 12:05 AM. |
