-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   Heater Fan (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/heater-fan-56038/)
Mgiudice 03-01-2011 11:52 AM
Heater Fan
my fan is not working and we just keep getting snow piled up over here. Where is the fan located or how can i fix it. It started with low med High then low high then high only but now nothing. Help please.
mxpxpunkrock1987 03-01-2011 12:13 PM
the sensor thats a coil next to your fan is bad let me get the name for u heater blower control switch basically its a resistor
theonetruetom 03-01-2011 12:58 PM
the blower motor is on the passenger's side, bolted to the firewall. there are a couple of tricky bolts to get at down there, but with 3/8" elbow you might be okay.
rob180 03-01-2011 08:22 PM
Sounds like the blower motor relay. Located on the passenger side. Inside the blower assy. Kinda have to lay on your head to get to it. It will have a green looking circuit board and you should see alot of burning and flaking on it. Had the same issue on my Venture and a Impala.
JustJerry 03-02-2011 05:19 PM
Blower motor is not that hard to replace. I've had to put 2 of them in my 92 S10 that has 160,00.
