Hesitation upon Hard acceleration
91 s10 blazer 4.3 4wd.
new fuel pump fuel filter air filter plugs (ac delco,i have not replaced the cap & rotor yet) tps iac egr cleaned most vacuum lines replaced. I have a 02 sensor code showing only when im cruising a steady speed for a period of time. The cat was bad so i cut it off and until Friday im running open pipe right after the sensor. Is it maybe that that's causing the sensor code to pop up? When I floor it. the motor jumps up to 3500 or so as normal but the motor starts hesitating and having no power. If i gradually ease into it the blazer is fine. I just got the blazer with a bad pump and Ive been driving it for 2 days. |
| All times are GMT -5. The time now is 04:48 AM. |
