-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   high flow air (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/high-flow-air-7188/)
ltsaunders 12-07-2006 03:38 PM
high flow air
I put a k+n open filter system on my 4.3 vortec and have had problems with starting and basic performance. I put a jet chip in it and it seems worse. It is only hard to start cold. No leaks in the fuel system. It almost sounds like it's missing so I replaced all the ususal stuff plugs wires filters excet. no luck. Could high flow be incompatable with the mass air sensor?
swartlkk 12-07-2006 04:13 PM
RE: high flow air
I'm betting that you have a dirty MAF sensor. Run a search and you should find a ton of information on it. Here's a quick reference:
https://blazerforum.com/fb.asp?m=26733
Good Luck
