-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   Is high performance coil worth it? (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/high-performance-coil-worth-36870/)
rastoma 11-10-2009 07:58 PM
I haven't done any other mods to my Blazer, still trying to get it run 'perfect' (if that's possible).... still fighting a very slight surge on and off... also doesn't seem to have the power this size engine should have.
It has the stock coil on it.
I see a MSD's Blaster GM Coil at Oreilley's for $39.99 vs a standard OE style for $19.99.
If standard OE style wires are being used will a supposedly 'high performance' coil do anything for me?
old skool luvr 11-10-2009 11:16 PM
i had that MSD coil on my '92 Jimmy. didn't really notice much difference in performance, but my truck was stick, and i was always "foot down, rowing gears". i did notice that my plugs stayed cleaner than before.
rastoma 11-11-2009 04:28 AM
Are/were you running standard wires or 'high perf.' wires?
Sounds like for $20 difference it wouldn't hurt to get the MSD anyway?
neo71665 11-11-2009 05:11 AM
The factory coil is actually hotter than the engine needs anyways. If your coil is bad and you can get the MSD one cheaper than a ac delco then by all means go ahead. If not then just get the factory one. I'm running an MSD on mine and you won't notice a bit of difference, even with running the msd wires.
