-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   Hole in my door sill (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/hole-my-door-sill-102692/)
Dutch S-10 Blazer 12-11-2020 12:56 AM
Hi everybody!
I have a question, my ‘92 S-10 Blazer has a hole in the door sill (bought it like that), what can I do to prevent rusting?
Thanks in advance!
https://cimg3.ibsrv.net/gimg/blazerf...2f9d85629.jpeg
https://cimg4.ibsrv.net/gimg/blazerf...c5ccfd9b7.jpeg
AJBert 12-11-2020 06:18 PM
First, clean up any existing rust, then put some type corrosion control on the back side, hammer down the edges of the split/cut and welded it up. Grind down the weld nice and smooth. put body filler on and sand, prime and paint.
If this is beyond your skills, get a couple of quotes from some body shops. Shouldn't cost to much as it is a fairly easy fix and shouldn't take much time on the labor side. The number 1 thing I would be concerned with is getting that corrosion control taken on the back side and/or inside the rocker.
christine_208 12-11-2020 07:35 PM
Basicly ditto to what AJBEST wrote.
I'd suggest considering tbe use of this internal frame coating product.
https://www.eastwood.com/eastwood-in...waApCkEALw_wcB
