How to check fuel pressure?
Old Jul 24, 2013 | 06:33 PM
wild bill's Avatar
wild bill is on a distinguished road
Default How to check fuel pressure?
Have 1990 with 4.3 TBI. How do I check the fuel pressure, and what should it be?
Old Jul 24, 2013 | 07:22 PM
chris015's Avatar
you need this guy right here
TBI Throttle Body Injection Fuel Pressure Gauge Adapter | eBay
plus the fuel test kit. hit up autozone etc. its totally free,but because of lowlife thieves,you have to leave a retail deposit. i think its about 100 bucks? Not sure. been a while.
Old Jul 24, 2013 | 07:34 PM
cleburne red's Avatar
It's more like $150-$160 for the deposit down here. But yeah, like chris said, you get it all back when you return it. Rotten thieves!
Old Jul 25, 2013 | 07:05 AM
wild bill's Avatar
Thanks, any particular place that the adapter screws into?
Old Jul 25, 2013 | 10:18 AM
chris015's Avatar
Yep,right behind the throttle body.
Old Jul 25, 2013 | 12:39 PM
wild bill's Avatar
thanks, what should the pressure be?
Old Jul 30, 2013 | 05:43 PM
wild bill's Avatar
checked fuel pressure, between 7 and 8 psi. at idle. What should it be?
Old Jul 30, 2013 | 05:48 PM
chris015's Avatar
gotta be between 10-13. Best you can do is rebuild the throttle body,if its still low,its the pump. Buy whatever brand rebuild kit,but stick to ac delco on the pump. Unless you enjoy changing them every 2 months.
hint : to bump pressure a 1lb or 2,stick a quarter on top of the regulator spring before you reinstall it. google "quarter mod tbi". ive done it. made a difference.
Old Jul 30, 2013 | 06:05 PM
wild bill's Avatar
since it is low, does that mean it is the fuel pump? I tested the pressure between the tank and the filter.
Old Jul 30, 2013 | 08:26 PM
chris015's Avatar
Ah! in that case. Yes pumps weak. Remember to buy only ac delco. You can get one from rock auto for 40 bucks. Cheaper then a aftermarket.
