i hit about 220° before it opend then went to about 190°
Does that sound right or is that to hot
Sounds like its sticking
Yup I'd swap out the tstat ASAP!
my 94 does this. With the old tstat and with the new failsafe. I dont loose coolant. It's only at 220 for a few seconds, and even so that's not real damaging so i dont concern myself with it too much. You can change the thermostat just to be on the safe side.
i dont know if its a good thing but my 93 has been this way since i bought it 4 years ago. always scares me, gets up to lke 220 then goes down to 190. maybe it has something to do with where the temp sending unit is or something
Ya it only hits it for about a second or so but Ya I still might switch it for a new 1 to be safe only had the truck a week
maybe its already open when it hits 220 its just the antifreeze moving from the combustion area past the sender. I`m over thinking this :)
Naw. mine did this when i got it. swapped the stat and fixed it. Its sticking SHUT. once it finally fails you'll overheat. stats like 5 bucks? and takes 10 minutes to change it. cmon man.
I agree with chris. Mine was sticking for less than a week (doing just as you described) Then it left me stranded in the middle of downtown lansing, running very hot. When I got it home I replaced the thermostat and its all been good ever since. A normally functioning cooling system SHOULD NOT ever exceed 210 under normal circumstances. Just my 2 cents :icon_eddie:
Thank for the help guys :)
| All times are GMT -5. The time now is 02:27 AM. |
