Ideal idle RPM
What's the factory and/or ideal idle RPM for my 4.3 TBI engine? Mine runs at 1.3 - 1.4. Is it normal or too high as I think?
Originally Posted by 89 Blazer Lebanon
(Post 408166)
the truck should idle anywhere from 550 RPM to a max of 750/800 for a manual trans'd vehicle. of course, the engine will idle slightly higher when it's cold (not warmed up). |
(Post 408180)
ok, i kinda thought you meant 1300 RPM, but didn't want to assume.
start checking out your IAC (Idle Air Control) it could be dirty or just plain broke. be careful though, i had one shoot the plunger out completely once (it was off the truck for cleaning) and it never worked after that. you'll also want to check your throttle body too. make sure nothing is making the throttle plate stick open. even if it's stuck open just a little, it'll affect your base idle speed. question. you've been a member for quite awhile now, is this something that has just happened recently? |
(Post 408364)
Your idle speed is controlled by the IAC.
Originally Posted by rriddle3
(Post 408429)
Clean or replace the IAC and its connection. The 'search' function should help out.
| All times are GMT -5. The time now is 07:06 PM. |
