| 4X4 forever |
02-03-2011 03:17 PM |
ignition timing decreases as TPS increases
Hi all, Great info on this site. Just picked up a 93 S-10 Blazer 4.3, for 3rd vehicle/ kids work car. Previous owner has a stack of recent receipts including fuel injector spider, ignition module, transmission. Vehicle would shut off and not restart for 30 minutes. Using your info, I determined it was the fuel injector connection. Next problem is lack of any power at wide open throttle. I use a Snap-on scanner, no codes, while driving vehicle and monitoring scanner data, vehicle runs strong as long as TPS is 30% or less usually less than 2 volts. When TPS increases above 30%, ignition timing drops to 10-15 BTDC. If I drive and monitor timing and keep timing at 30 BTDC vehicle runs strong. Will power brake, chirp tires at 1-2 shift. If I exceed 2V or approx 30% TPS timing falls to 10-15 and vehicle will not accelerate even when going down hill. I have been looking for info on this problem for several weeks and have not seen anyone else with this issue. I installed new AC plugs, wires, cap, rotor, coil. Looked inside upper intake for characteristic FP/spider problems, passed leak check. Any help would be appreciated, this vehicle is clean inside and out, just has performance issues. Thank you.
