ISO: Plug wire loom brackets
Old Apr 3, 2020 | 10:11 AM
jkyle187's Avatar
jkyle187 is an unknown quantity at this point
Default ISO: Plug wire loom brackets
Can anyone help? Need pics, part #s and help identifying which wire loom brackets im missing. I know one it attached to dipstick. Would like OEM # for the plastic clips. Any help is appreciated.1992 block 80 HD trike..
Old Apr 3, 2020 | 07:16 PM
Default Sorry off topic
I would like to see more pics of that trike!
Old Apr 4, 2020 | 05:38 AM
Definively more pictures!
As for the parts It's not easy to find pictures. Tried a quick look at GMPartscenter and Rockauto. No luck, the parts are not on the drawings.
May need to look on different models around these years. Several trucks and cars used the same parts. As for the location once putting the wiring onto the engine the location of the looms should become apparent.
I've fixed a puzzle of mounting brackets and supports on a 1963 Studebaker Avanti. They had not marked the parts and no pictures. No luck with the drawings either. Took 3 hours to figure that one.
Old Apr 4, 2020 | 08:12 AM
jkyle187's Avatar
Default project 1980 HD 4.3 v6 trike
i will post a few to give u idea of trike...i have tons of my progress..and will not cloud this forum with boredom
marine intake w/ 2G carb
Last edited by jkyle187; Apr 4, 2020 at 08:33 AM. Reason: fellow user asked for more pics
Old Apr 10, 2020 | 04:23 AM
nice, thanks for sharing the views
Old Apr 10, 2020 | 10:39 AM
eshaw's Avatar
Let me guess, you're running a Turbo 350 or Powerglide direct to a fixed suspension rear end?
Old Apr 10, 2020 | 06:50 PM
jkyle187's Avatar
250c trans 69 Camaro short & narrowed rear end, yes ridged frame..
Old Apr 10, 2020 | 08:28 PM
eshaw's Avatar
When your front tire wears out get you the cheapest radial tire you can find, they work excellent. I did something similar. I took the center section out of a 9 inch ford and grafted half shafts to it, kinda like a vette uses. That way it keeps the center fixed for the hook up to the trans but allows the tires to be independently sprung.
Old Apr 17, 2020 | 07:47 PM
jkyle187's Avatar
Old Apr 18, 2020 | 01:57 AM
looking great. where did you finally source the brackets?
