-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   just need some opinions (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/just-need-some-opinions-65665/)
xgiovannix12 12-04-2011 06:58 PM
I decided to change the starter on my truck since it started to stick
I use to have to bang it with a hammer for it to start
any ways for a year 1/2 i had a random click also
I thought it was the solenoid on the starter so i waited for the starter to start sticking witch it did
any ways i still got the click after replacing the starter today
the battery was replaced this year
I was thinking that the cables are bad . Is that possible ? the click is random sometimes it starts on 1st shot
thanks for reading
warthogdriver 12-04-2011 10:01 PM
I have a buddy who thought hia starter was going out would bang it sometimes. Finally replaced it. Still had the problem, turned out the cable from battery went bad as well as the harness going from starter back out. Wound up having to replace the cable and then redid ends on harness. Only reason we figured it out was we tried jumping it and no spark. Circuit was broken.
xgiovannix12 12-04-2011 10:06 PM
yea i went to advance and the truck started fine i went to get gas and it started fine
I went home i tryed to start it again click click then after the 3rd try it started
I had to replace the starter any ways since it was starting to stick
I bought a pos and neg cable
thanks warthog at least i know im going in the right direction
Chevy33 12-04-2011 10:19 PM
I just live with it.
My 95 Jimmy does that same click thing. When it happens if I have time, I get out and run around it twice tapping the hood as I go round. If I don't I just rub the dash until it feels like starting. This has always worked for me.
At times my fuel pump relay will not work. If I put a new one in and turn the key it will work. Then before I start it, I put the old relay back in and turn the key and it will work again. I must always keep a spare fuel pump relay in the glove box. Needless to say I don't loan my Jimmy out much.
xgiovannix12 12-06-2011 08:39 PM
witch wire theres 3 on the pos one going to the starter one for the alternator and the other goes under the rad i dont know whats that for
I changed the pos cable today and the truck started great till i went somewhere and it clicked when i tryed to start it when i was going home :icon_shrug:
tomorrow ill be replacing the neg
chris015 12-06-2011 08:56 PM
Id do the big 3 while your in there...or at least change out the wire from the alternator to the battery.
xgiovannix12 12-06-2011 08:58 PM
yea i can splice a new one in at any time
I just wanna fix this dam random click its annoying
chris015 12-06-2011 09:01 PM
Mine has yet to do the random turn key nothing happens thing. I hope it was just a bug that fixed its self.
Its got to the point now that anything thats wrong with the blazer can just sit there. As long as it cranks and runs i dont care. Im tired of throwing parts on it lol.
xgiovannix12 12-06-2011 09:03 PM
yea id hate to do that tho
im still open to suggestions guys
I just hope that ground fixes it
xgiovannix12 12-09-2011 07:43 PM
hey guys i didnt swap out the neg cable yet but
I did some more research and found out this truck has a starter switch
this is what it looks like
ACDELCO D1404B Seat/Seat Accessory | eBay
is this for the starter ? I never heard of one and turns out its located in the steering column
