keyless entry code on a 94
Old Apr 29, 2009 | 08:09 PM
classklown90's Avatar
classklown90 is on a distinguished road
is ax3 the only code for keyless entry?
btw there is a little orange bul on the left side of my steering wheel down a bit and it does not light up or anything. any clue what this is?
Old Apr 29, 2009 | 10:13 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
No, AU0 also appears for keyless entry.
The bulb sounds like an aftermarket alarm or keyless entry/remote start add-on.
Old Apr 29, 2009 | 10:23 PM
well i do not have either of these codes. how do i make the alram active again and does this mean i have keyless entry anyway?
Old Apr 30, 2009 | 07:14 AM
The only two I have seen are:
AU0 : LOCK CONTROL, REMOTE ENTRY – KEYLESS ENTRY (DOMESTIC)
AX3 : LOCK CONTROL, KEYLESS ENTRY SYSTEM
As far as the light is concerned, factory RKE systems did not have a light.
Old Apr 30, 2009 | 09:05 AM
If the light isn't getting power, more than likely it was left behind when a previous owner removed the rest of the add-on stuff.
Add-on alarms and remote entry systems often are poorly installed and cause all sorts of ignition and electrical problems. Someone added remote entry/remote start to my old 240sx and it drains the crap out of the battery if left on - in about 2 days.
Old Apr 30, 2009 | 11:01 AM
cage47's Avatar
cage47 is on a distinguished road
Sure they do. My father has a 1996 GMC 1500. It has a factory installed alarm. It has a small bulb on the dash just to the left of the steering wheel. Uses the standard Gm keyfob. It blinks when the alarm is active.
Old Apr 30, 2009 | 11:52 AM
Anything that is on a lower dash panel is not a factory installed option. Maybe a dealer installed option, but not factory. Factory stuff is either in the cluster or in another portion of the upper dash (near the ambient light sensor for example).
On the s-series, there is no factory status indicator other than the "security" light in the dash, but that is only on 98+ IIRC.
Old Apr 30, 2009 | 12:00 PM
thanks im definetly goona get this checked out ill let you know
Old Apr 30, 2009 | 12:09 PM
nvm i found a black box that says sensor and has a red light on it but the wire is cut and has a black,orange,brown and red wires. then i found a group of cut wires going to the bulb they are: blue green and orange. then i found a large whitish tan wire going to my dash and finally i found a fat orange and small pink wire that were cut but were grouped with a thick yellow wire. how do i reconnect this?
Old May 9, 2009 | 12:48 PM
bluebeast's Avatar
bluebeast is on a distinguished road
how early did they start using remote keyless entry? i have a 92 and im doubting that it would have this option, but it would be super cool if it did. if a person was to find the module or whatever for it, could it be installed into an earlier year of blazer?
