looking for help
first let me say I am used to my 70 K-5 it is simple but I have a 94 S-10 4.3 W engine that was pulsing and had bad mileage I put a EGR valve on that did not fix it, so checked the fuel pressure regulator and found that it was leaking and also found a broken stud on rear of intake. Fixed that now it has a very high idle and then has an intermittent miss. Could this be the IAC I am out of ideas and it is the wife's truck so I am not getting any rest till it is fixed
Yeah I would go for the vaccum leak first. You can spray carb cleaner on all the hose connections while the engine is running and if the RPMs go up you found a source for a leak.
You might want to check the throttle linkage maybe the cable didnt fall into the groove and is holding it open a little too?
Did you clean up the junk out of the EGR ports too?
If its running like poop it should be giving you a check engine trouble code, jump the connectors and tell us what codes you are getting.
If you vaccum line connections are loose or wobbly you can trim the hose end off and put it back on, some people like me also run a ziptie on real tight just to make sure kind of like a hose clamp. Pay special attention to your PCV valve Ive seen a million of them thats loose, it seems the rubber they make the grommet with doesnt like years of exposure to oil and they get fluffy and dont hold the parts in tight.
dbleon
Engine & Internal
27
Sep 26, 2008 03:55 PM
kmd1776
May 16, 2008 07:44 PM
bodean
Nov 23, 2007 12:26 AM
chevblazer02
Dec 11, 2006 02:48 PM
