Loosing antifreeze.
Old Nov 19, 2012 | 02:54 PM
Guestaloompa's Avatar
Guestaloompa is on a distinguished road
Default Loosing antifreeze.
I normally wouldn't ask for help with such a noob task (finding a leak), but I absolutely cannot find the source. All I know is that it ends up coming out of a small hole on the transmission shield and is a steady drip so it leaks out rather quick. It needs a good gallon every 2-3 days. Anyone ever heard of anything similar? This is a 94' 4.3 vin W by the way.
Old Nov 19, 2012 | 02:57 PM
chris015's Avatar
transmission shield as in a skid plate? or torque convertor cover? if its coming from the rear,only thing that might be the problem is a freeze plug,or maybe rear of intake manifold.
Old Nov 19, 2012 | 03:14 PM
Yea the one over the torque converter. I hope it's not a damn freeze plug.
Old Nov 19, 2012 | 03:17 PM
chris015's Avatar
yea,they arent exactly the best thing to repair. Another thought is this,im not sure if the 94' has it but my 91 has the heater hose that runs into a fitting on the passenger side of the distributor. That may be leaking and running down the block.
Old Nov 19, 2012 | 03:31 PM
That's what my Dad just now said.
Old Nov 19, 2012 | 03:37 PM
chris015's Avatar
Yea,whatcha need to do if you cant find it is go pressure wash everything real good,and wait till nighttime,jack her up (use safety jacks!) grab a bright flashlight and start searching for the leak. Reason i say at night is the daylight glare etc can be a nuisance.
Old Nov 19, 2012 | 05:20 PM
Diaita's Avatar
could be lower intake manifold gasket. check the valley between the valve cover and intake manifold.
Old Nov 20, 2012 | 04:38 AM
Thanks for the suggestions, peeps. I work graveyard so I'll try these mid afternoon today. Thanks again, I'll let you know!
Old Nov 20, 2012 | 06:56 PM
ohsofly's Avatar
Check the rear intake down below the distributor really good. Thats a known weak point.
Old Nov 21, 2012 | 09:12 AM
I've checked everything but I'm going to double check. Sorry for delayed responses, I work 3rd shift and have been struck down with some sort or cold/strep throat.
