May have found rough idle cause (with pics)
Ive been fighting a rough idle for a while, fixed various vacuum issues, fuel spider, etc. Just to cover all my bases I lined the timing mark up to the notch (#1 at TDC I think), took my distributor cap off, and found the button pointing at about the 10 o'clock position (see photo). My tech manual said it should be more like at the 6 o'clock position. Am I 180 degrees out?
Thanks as always.
Thanks as always.
After reading all night on here, pretty much decided it cant be 180 out or it wouldnt run good at all. Im gonna rotate the crank around one more revolution and see where it points.
I changed the distributor cap and button, wondering if that could have thrown the timimg off a little.
Is it giving you any codes? SES light on? I had a rough idle and it ended up being a bent valve. I had replaced cap, rotor, plugs, wires, spider injector, egr valve screen, and cleaned maf and pcv valve. None of that worked. I should have got the compression test first...
No SES code, replaced everything you did, and should have done the test first. However the spider was toast and it has smoothed out some, but I guess I need to research a positive pressure test to pinpoint the problem.
Thanks guys.
Thanks guys.
Squirted some oil in, no change. Guess I found my rough idle. What does that mean mechanically?
