Need help ASAP!!!!
Here is the situation I did a Seafoam treatment on my blazer about a month ago due to it running badly and it worked perfect but the past 2 days it has been running like complete junk like worst then it was before and I would Seafoam it again but it says to only do it once every 10,000 miles are there any other suggestions to help me get my rig running better it is not getting a lot of power and it makes these popping noises and stalls out this all mainly happens when I am going up hills or going slow please help this is my daily driver
I start diagnosing the fuel system
96+ Fuel System Diagnosis - Blazer Forum - Chevy Blazer Forums did it rain recently by you ? any ses light ? |
did you seafoam the intake oil and gas...or just one of the three??
when was last time you did tune up or fuel filter....we need some history please. |
opps you have a tbi the fuel system diagnoses is the same
the pressure should be 15 to 16 psi when you turn the key on |
Originally Posted by warthogdriver
(Post 484849)
when was last time you did tune up or fuel filter....we need some history please. I seafoamed the gas and also put it in the brake booster line only thing I didn't do was the carb the fuel filter was replaced around the same time I did the seafoam treatment it also had an oil change within the last 300 miles hope that helps |
(Post 484850)
(Post 484848)
96+ Fuel System Diagnosis - Blazer Forum - Chevy Blazer Forums did it rain recently by you ? any ses light ? that diagnosis seems to be a lot of work and it probably requires equipment that I don't have and yes it has been raining for the past 2 days here but I don't see how that will effect anything it has been rained on before with no issue and what is an ses light ? I googled ses light and to answer your question no there has not been any lights or anything out of the ordinary |
Originally Posted by swartlkk
(Post 484861)
TBI fuel pressure spec is 9-13psi for his application, not 15-16psi. Following your numbers could lead to unnecessary replacement... Best to check your facts before posting. Also, a TBI fuel pressure test port 'T' adapter is necessary to test system pressure on a TBI engine; installation of which requires the main fuel line be disconnected from the back of the throttle body & the adapter installed in-line. A test port was not provided on a stock TBI fuel system.
Originally Posted by 89Recon
(Post 484863)
and the ses light is the service engine soon |
(Post 484863)
(Post 484865)
Problems when it's wet/humid out could indicate an ignition system problem. Once it's dark out, park in an area where there is next to no light outside. Using a spray bottle, mist down the wires & distributor area with the engine running. If you see a light show, spark is leaking from one or more of those components (wires/cap). Aftermarket caps & rotors have been known to have problems in damp conditions when used in these vehicles. If the cap/rotor were recently replaced with an aftermarket replacement, that is where I would start.
| All times are GMT -5. The time now is 08:24 AM. |
