-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   Need Shift Cable Housing Part Number (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/need-shift-cable-housing-part-number-85778/)
dontcrossme May 13, 2014 09:52 PM
2 Attachment(s)
I tried to search the forums and the web but can not find this part number. I want to order a new one.
Its the one with the 16mm nut on the end of the cable going into the housing. I need to replace the cable and I can not get it out of the housing and its now stripped. I need to replace the housing but can not find the part number. Can anyone direct me to website that lists it or its exact part number.
I circled the part I need in the the attached image. Basically the plastic part the covers the cable attachment going into the front output shaft. It has 3 bolts holding it to the shaft and the cable and sensor on the longer side.
Thanks for any help.
rexmburns May 14, 2014 07:37 AM
Try this!
12471585. GM. HOUSING. Front Drive Axle Shifter/Lock. DIFFERENTIAL CARRIER/FRONT AXLE.
