NEW PARTS BRAKES STILL STICKING
so i went and got a new caliper for the right side and cleaned the slide pins and made shuer the pins where not bent then I put it togauther bled the hole thing
and the front right side still sticking 93 4.3 4x4 blazer 96 grand AM |
RE: NEW PARTS BRAKES STILL STICKING
Colapsed or twisted brake hose.
Make sure the brake hose isn't twisted, if not then it has colapsed, replace it. |
Change the lines to that wheel. The bake lines collapse on the inside where you can't see and prevent the fluid from flowing back when the pedal is released. if it's still sticking after you changed the caliper the next step is the line. change all lines going to that wheel. That should fix your problem.
... 2+ years old...
