No check engine light
Hey so Ryan here i have a question, i just bought another S10 blazer yesterday and someone had messed with the check engine light. IDK what i have to do to replace the bulb or what wires will be cut. do i have to take the dash apart to get to that bulb?? Also the water temp gauge looks like its been disconnected where would that be on the block??? thanks!
1994 S!0 LT Tahoe 251,xxx 1993 S10 LT Tahoe 159,xxx |
2.8 or 4.3?
as for the cluster,remove the bezel around it,the hvac control,and the headlight switch. the cluster has a few 10mm nuts. remove em and you'll see whats there. it'll be some small bulbs with a twist and pull style connector on the back of em. |
4.3 and so i new i smelled gas on the way home (i bought it 100 miles away from where i live) and i got home and started looking for a leak and boom i have a rust hole in my gas tank lol it was fine until i filled it all the way up and it reached the hole in the side of the tank so i spent all day taking that off and looking for a new tank. i will try to work on it this weekend due to being without a tank and at my folks house 60 miles away lol thanks for the help chris
