-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   oil cooler line (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/oil-cooler-line-7140/)
FImports 12-05-2006 11:32 PM
oil cooler line
whats the easiest way to remove the oil cooler line on a 92 s-10 blazer..........thanks
rooster 12-06-2006 01:33 AM
RE: oil cooler line
well if its the one that goes from the oil filter to the eng then u will need a very long 2 ft extension and a floor jack and a piece of wood. the bolt heads i believe are 9/16, along with a 1/2 ratchet you will need to feed the socket and extension through the steering linkage area towards the bolt. oh but before that u might need to jack up the eng slightly to get past the motor mount. so put the wood under the oil pan and lift it with the jack.so after u feed the extension through then carefully remove the old lines, and install is the reverse of removal except be very carefull when feeding and turning the new lines into position. u dont want to crimp or disturb the fittings on the lines. otherwise the cooler line is pretty straight foward, two bolts off two bolts on.
FImports 12-06-2006 04:56 PM
RE: oil cooler line
thanks for your help.should i drain the oil first
rooster 12-06-2006 08:28 PM
RE: oil cooler line
no thank u, but yes drain the oil and do a complete change with filter. its cheap enough
