oil lines
i have an 89 s 10 blazer with a remote filter on the fender, i want to remove the lines and go back to the filter under the motor, where can i get the right parts for the filter assy?
Assuming it is a 4wd, you have to use a remote oil filter. There is not enough room for an oil filter in the normal location.
You could also try buying the short filter and trying it, I have never tried though. My blazer takes a WIX 51036 filter, and a 51040 is the smae thing but shorter. My cavalier could use either, so I imagine the truck can use either too.
You are having a prolblem with it leaking, try removing the remote filter assembly and taking it to a hydraulic shop, the guys there will be able to remake it for you around fourty bucks using the old ends and new everything in between. |
If you are leaking you could also replace the oil lines. I had a leak on the remote lines and was able to get new ones from LMCtruck. They weren't too expensive, but not cheap either...
| All times are GMT -5. The time now is 05:10 AM. |
